2019 Rear shock noise
Discussion in 'Ford Raptor Suspension Discussion and Modification' started by Sean Yudice, Mar 24, 2020.
  1. Sean Yudice
    Sean Yudice Member
    Mar 24, 2020
    Fairfax
    I have been trying to figure out a noise in my rear suspension for the last couple of months. It sounds like i have a baseball in the bed of the truck when I drive in a driveway or go off camber a bit, not off road. I had a couple of my buddies over and we jumped on the bumper and you can hear the noise coming from the live valve Fox shocks. I disconnected the bottom bolt of both shock and then jumped on the tailgate again with no noise. It is definately the shocks. I took it to the dealership and they said they can hear it but Ford will not do anything because the shocks are not leaking. I told him this is a $80K truck under warranty and this should not be happening. He said he will send it off to engineering but I have not heard anything back in 3 weeks with numerous calls. They will probably blame it one the Corona virus.
    Anyone have this issue.
    I wish I had my 2013 Raptor back!
    JoeCaMotto likes this.
  2. WynstonWolf
    WynstonWolf Member
    41
    9
    Apr 19, 2019
    Delaware
    Hey man don’t know if it helps, but my 19 will sound like the shocks are banging around if I’m going slow over rough terrain like logging road or unpaved dirt roads. It’s not bad enough to make me concerned I just figured it was the shocks doing their job and allowing suspension to be extra loose to soak up bumps. Not saying same thing just throwing an idea out. Good luck man.
  3. FordTechOne
    FordTechOne Full Access Member
    855
    792
    Jul 29, 2019
    Detroit
    What is your build date?
  4. Gsteve
    Gsteve FRF Addict
    59
    1,295
    451
    Dec 11, 2013
    its normal
  5. JoeCaMotto
    JoeCaMotto Member
    46
    28
    Mar 15, 2018
    Chitown
    I hear a slight noise from mine also, Apr 2019 built
  6. Donmatteo
    Donmatteo Full Access Member
    421
    258
    Jul 5, 2018
    Santa Clarita
    ditto on the noise and build date.
    It's not bad. I've only heard it a couple of times.
  7. Gsteve
    Gsteve FRF Addict
    59
    1,295
    451
    Dec 11, 2013
    They all have it.
  8. CHMP
    CHMP Full Access Member
    139
    62
    May 28, 2019
    Santa Cruz
    Probably a silly question, but what psi are your tires set at? I found my truck got far quieter / comfier after going 36 FR / 34 RR (unloaded bed).
  9. Donmatteo
    421
    258
    Jul 5, 2018
    Santa Clarita
    Im at 35 all around
  10. JoeCaMotto
    JoeCaMotto Member
    46
    28
    Mar 15, 2018
    Chitown
    I run 40 psi all around.
Share This Page
