Tracking of built truck on chip hold now says “not yet available for tracking”
SR12
NC
so, it is not a chip shortage.
mine is confirmed chip hold as of monday. 11/8 build date. probably missing fender flares as well but can't confirm. Regardless, "in production" since 10/29, had a delivery ETA of 12/6 then 12/31, now no ETA and the same issue as everyone else on the ford tracker "not yet available for tracking" or whatever it says.
EMY92
Woodway, TX
Going to the other tracking sites since Ford's isn't working, my ETA is still 11/09. Even if the Ford site was up, it would show the same since they call the same API.
BadWRP
The Ford Tracker doesn't work and have been using the Mach E tracker instead.
Every time I check, the estimate days to delivery increases... Of course it does!
Same, I feel like the Mach E tracker punishes me every time I check it by adding another day. Like the soup **** yelling at me "No truck for you!"
mully722
Tucson, AZ
Anyone have any movement on their hold?
My truck had a build date of 11/16, yesterday the ETA was 12/24 now it’s 12/31... Don’t tell me I’ll get my 2021 in 2022.
sadly, you have seen more movement than the rest of us. (ETA date change) my 9/28 build date ETA switched mid October from 10/31 to 12/31 and hasn’t moved since.
Jr24
Middle Tennessee
I'm jealous yours even shows an ETA. Mine was built 10/23 and originally said delivery 11/21 then 12/31 and now TBD. At this point I figure I'll be lucky to see it sometime in January, and by then they'll probably be digging it out of a snow bank to install the fender flares and whatever else its missing.
CenTexRaptor
Austin
Where are you seeing the TBD? The Ford tracker just says "not available" for me, but the Mach-E and direct to API are still showing a 11-08 delivery date. I kinda thought that would change, based on what others have seen, but so far, it has remained at that. I am still hoping someone did a typo... and what is 11-08 really should be 12-08... (I know... wishful thinking...)
