FOX 3.0 first on road driving impressions
HawaiiStevo
Palos Verdes CA
I had the FOX 3.0 coilers installed on my 2018 Screw by SVC a little over a week ago. Before anybody gets all excited about why only driven on road, just calm down. I will test them in the dirt as time permits.
Initially I was going to go with the SVC spacers to level the front end ( I love my truck but could not get past the front end rake and wanted to level it) but I thought that might harshen the ride significantly by changing the spring rate. My on road driving impression are as follows:
Very similar to stock on dips and undulations on the freeway (low speed compression). On harsh hits such as big pot holes (high speed compression) and such the suspension is definitely stiffer than the stock ride. However there is adjustability on both the hi and low speed compression. Initially my high speed compression was set at six clicks in CCW. I felt this was a little to harsh on the street so I backed it out 4 clicks. This helped significantly. The ride on the street now is very similar to stock but with less brake dive and roll on turns. The best part is they are adjustable so I am looking forward to playing in the dirt as time permits.
Currently the truck sits about .5" high in the front. I love the way it looks now.
The guys at SVC off road in Lake Forrest are awesome! From what I can see they did an awesome job at a very good price. They appeared to be very busy but Jeff still took a little time to explain the install and basic functionality. These guys look like they live and breath off-roading. I will definitely be returning to them.
svc
Worldwide
Thank you again Steve!
Ruri
SoCal
Aren’t the Fox coilovers from SVC supposed to be tuned or set by SVC? What I’ve read is Fox doesn’t give any base settings like the King coilovers do.
Aesconde
Nice write up. I have collars on now but Amy trying to decide between kings and foxs
HawaiiStevo
HawaiiStevo
Palos Verdes CA
No they are not " tuned" by SVC, or at least mine weren't. That would require adjusting the internal rebound and compression circuits. Am sure they are capable if desired. However the hi and low speed compression adjustments were set by SVC according to the FOX Racing recommendations.
The ride hight adjustment is accomplished by compressing or extending the spring which also affects the ride. You propaply already know all this so I apologize if I'm being redundant. So in a nutshell, no mine were not tuned by SVC, however the ride hight was adjusted to my request.
I did contact FOX and they sent me an email with the basic settings (starting point) for the front coilovers and the rear shocks. Again this is a starting point only. FOX did say they are working on a more comprehensive guide which should be out soon.I'm no suspension expert by any means so please consider this my opinion only. Just trying to pass along info. If you have any questions call Jeff at SVC, I am sure he would be more then happy to help you.
