What have I done
c Wilson
North carolina
New to the forum. Working on my 2017 raptor trying to put in some rigid radiance fogs. I’m not the greatest at electrical stuff but I figured it out once I read the left bunch of wires were the hot set not the right. Anyways now having issues with starting the truck. The interior lighting works and the headlights works and power seats and the button even lights up green to start ignition but nothing happens. The media screen also isn’t working and doesn’t turn on when you open the doors like it usually does. Power locks are not working either. Was thinking it might be a fuse or relay but not sure. Any help is appreciated and look forward to learning more every time I check back in here. Thnx
Welcome to FRF.
I would check the battery health. the computers disable the power lock sensors, and will shut down the radio, etc. Maybe check for diagnostic codes.
Oh, and pictures or it’s a prius.
C
c Wilson
North carolina
I removed the negative end of the battery to let it reset and when I plug it in and try to do the push to start even just for power to the car not to start the engine there is a noise and it stops however I can use my code reader to read error codes however there are none That appear. Which fuses would you recommend checking? I went through every one in the engine and on the passenger kickboard I thought was relevant but they all looked good.
K223
Florida
Welcome but obviously not under the best circumstances. I see a truck and a pooch so your in!
All fuses look good that you can see, and you disconnected the battery. We’re you only working with the upfitter switch wiring or did you tap into some other circuit at some point? Did you arc a positive against something at some point?
@FordTechOne Can you suggest what he can look at regarding this?
P.S. Pooches get you that extra help. Lucky for this pic LOL
Traffic22
SF Bay Area
Welcome. Nice looking dog and truck. Hope you get it sorted soon. Best of luck, keep us posted.
C
c Wilson
North carolina
I don’t believe I arced anything as I kept the wires didn’t come in contact with anything and I never even got them connected with the right up fitter switches. I had them connected with the pass through wires not the hot ones it seems.
CoronaRaptor
CANADA
Amp Rating Protected components
1 10A Demand lamp relay. Power seats relay. Glove box. Vanity lamps. Overhead console. Dome. Courtesy. Map lamps.
2 7.5 A Memory module logic. Memory seat switches. Lumbar motor.
3 20A Driver door lock motor.
4 5A Trailer brake control.
5 20A Not used.
6 10A Not used.
7 10A Not used.
8 10A Not used.
9 10A Not used (spare).
10 5A Embedded modem module.
11 5A Combined sensor module.
12 7.5A Climate head module. Smart datalink converter.
13 7.5A Cluster. SCCM.
14 10A Brake.
15 10A Smart datalink converter.
16 15A Tailgate release.
17 5A HUD. Terrain switch.
18 5A Ignition switch and passive-entry passive-start start stop switch. Key inhibit solenoid.
19 7.5A Tow haul (O/D) cancel for floor or column shifter.
20 — Not used.
21 5A HUD. In car temperature with humidity sensor.
22 5A EPB. Power seat.
23 10A PDRG switch. Inverter. Driver side window. Moonroof. Vista roof.
24 20A Central lock/unlock.
25 30A Driver door control module.
26 30A Passenger door control module.
27 30A Vista roof. Moonroof.
28 20A Not used.
29 30A Not used.
30 30A Not used.
31 15A Adjustable pedal switch and motor.
32 10A Multi-function display. Global position system. SYNC. Radio frequency receiver.
33 20A Radio.
34 30A Run-start relay.
35 5A Restraints module.
36 15A 360 camera module. Heated steering wheel module. Rear-view mirror. Rear heated seats.
37 20A Power distribution box run-start fuses.
38 30A Circuit breaker. Rear window switches and motors.
Assignment of the fuses in the Power distribution box (2017)
1 — Not used.
2 — Not used.
3 — Not used.
4 — Telescoping side-view mirror.
5 40A* Rear window defroster.
6 — Not used.
7 — Not used.
8 — Telescoping side-view mirror.
9 30 A* Fuel pump.
10 40A* Charge air cooler fans (Raptor only).
11 60A* Automatic brake system motor.
12 50A* Body control module 1.
13 60A* Body control module 2.
14 20A** Amplifier.
15 25A** 4x4.
16 10A** Spot light module.
17 15A** Heated seat.
18 10A** Steering-column lock.
19 10A** Power seats.
20 15A** Snow plow. Rear heated seats.
21A 15A** Transmission control module.
21B — Not used.
22 30 A* Windshield wiper motor.
23 15 A* Rain sensor.
24 2 5 A* Series fan feed.
25 — Not used.
26 30 A* Driver seat motors.
27 30 A* Passenger power seat.
28 30 A* Climate controlled seat.
29 25 A* Upfitter fuses 94, 96, 98 and 100 (Raptor only).
30 — Air conditioner clutch relay.
31 — Not used.
32 — Not used.
33 50A* Electric fan 3.
34 25 A* Trailer tow park lamps.
35 20A* Trailer tow stop-turn relay fuse.
36 25 A* Trailer tow lamps module.
37 50A* Electric fan 1.
38 10 A** Alt A sensor.
39 10 A** Integrated wheel end solenoid.
40 15A** E-locker.
41 10 A** Telescoping mirror.
42 30 A** Transmission fluid pump.
43 25A** Horn.
44 10 A** Air conditioner clutch.
45 10 A** Powertrain control module relay coil.
46 10 A** Wiper relay coil.
47 15 A* Upfitter 1 (Raptor only).
48 15 A* Upfitter 2 (Raptor only).
49 30 A* Trailer brake control module.
50 30 A* Power running boards.
51 — Fuel pump relay.
52 — Not used.
53 — Upfitter 5 relay (Raptor only).
54 30 A* Voltage quality module. Body-control-module voltage-quality-module feed.
55 40A* Body control module RP2 feed.
56 20A* Fuel pump.
57 30 A* Right-hand electric parking brake actuator.
58 30 A* Left-hand electric parking brake actuator.
59 30 A* Starter.
60 40A* Blower motor.
61 30 A* Brake control module. Automatic brake system valves.
62 — Power seat relay.
63 15A** Heated mirrors.
64 — Upfitter 6 relay (Raptor only).
65 — Starter relay.
66 — Powertrain control module relay.
67 — Windshield wiper relay.
68 — Blower motor relay.
69 — Power sliding back window relay.
70 — Electric fan 1 relay.
71 — Not used.
72 25 A* 4x4.
73 — Not used.
74 30 A* PDRG motor.
75 — Horn relay.
76 — Not used.
77 — Steering column lock relay.
78 — Not used.
79 — Trailer tow parking lamp relay.
80 — Rear window defroster relay.
81 — Upfitter 1 relay (Raptor only).
82 — PDRG close relay.
83 — Upfitter 2 relay (Raptor only).
84 — Not used.
85 — Not used.
86 — Not used.
87 10 A** Trailer tow backup lamps.
88 — Not used.
89 20A* Cigar lighter power point 1.
90 20A* Power point 2.
91 20A* Power point 3.
92 20A* Power point 4.
93 25A** GTDI vehicle power 1.
93 10 A** PFI vehicle power 1.
94 10 A** Upfitter 3 (Raptor only).
95 25A** Vehicle power 2.
96 10 A** Upfitter 4 (Raptor only).
97 10 A** Vehicle power 3.
98 5A** Upfitter 5 (Raptor only).
99 20A** Vehicle power 4 (PFI).
99 15A** Vehicle power 4 (GTDI).
100 5A** Upfitter 6 (Raptor only).
101 — Not used.
102 — Snow plow relay.
103 — Charge air cooler fan (Raptor only).
104 — Electronic fan 3 relay.
105 10A** Power steering.
106 — Not used.
107 10A** Anti-lock brakes.
108 — Not used.
109 10A** Powertrain control module. Transmission control module run-start power.
110 10A** 4x4 run/start. Adaptive cruise control.
111 15A** Transmission pump run-start.
112 10A** Charge air cooler relay coil run-start (Raptor only).
113 7.5A** Blind spot information system. Rear view camera. Front view camera. Voltage quality module.
114 — Electric fan 2 relay.
115 — Upfitter 3 relay (Raptor only).
116 — Upfitter 4 relay (Raptor only).
* Cartridge fuses
** Mini fuses
