I just ran the truck, 6th gear shift may have been my imagination. Unless there is a TC lockup that drops the RPMs more.
Yeah it has a TC lock up, might of been what you felt. You can usually tell the difference between gear change and tc lock. The RPM change is much greater with gear change. It might not be a bad idea to buy a cheapy code reader that will display live data. It will tell you what gear you're really in and other data that might help figure this out
I may just change that out to be safe. Any idea on cost?
its about 100 bucks. it could be causing the stall. if the canister valve is opening up when it's not suppose to, it essentially causes a vacuum leak
It is probably coming from the seal. We ran in 4x4 pretty hard on the beach for 4 hours or so. I simple greened everything down to get a better look at all.
Just got back from Orielly's too. Zero codes. They claimed that their reader is a good one that reads everything too. Truck ran fine on the trip. I pulled the intake hose off at the last hose clamp going into the engine, there was a small amount of dust, but nothing that concerned me. Where should I start looking? Kinda hard when the issue is intermittent.
so the throttle plate looked pretty clean? no carbon build up?
---------- Post added at 08:08 PM ---------- Previous post was at 07:34 PM ----------
Here are some pics of the underside.
PS hub with what appears to be oil on it.
Backside of the PS A Arm.
leaky PS axle seal.
