- Joined
- Dec 16, 2016
- Posts
- 16,479
- Reaction score
- 24,368
I am open to the possibility that it's the tires. But... The first set was a set of new Ridge Grapplers that had this issue. That is when I put the new KO2's back on to eliminate that possibility. (Sorry left that out) I Appreciate the help and advice. First shop was Big O that a friend of mine owns. The second was Discount tire. Thanks again!
That’s a purely coincidental change but it doesn’t really rule anything in or out because you don’t really have a ‘control’ - that is, your known, good, previous set of tires. You can ham fistedly test the mounted assembly in a similar way to bikers check chain alignment.
the tire/wheel needs to be mounted on the truck and be able to spin free or on a machine that will spin freely. put a fixed object like a pencil or chalk or something similar that won’t bugger up the wheel or tire right next to it, but not quite touching. slowly spin the wheel and eyeball the gap between your wheel and fixed object. Repeat with the top of the wheel or surface. spin slowly. This isn’t precise, it’s approximate. You may be able to rule in/out a wheel issue.
you didn’t rotate in the spare wheel did you, or change anything else?
