who is getting inner tire rub on drivers side fender well?
byz250f
For those that have put there Gen 2 through some off road use are you getting the drivers side rear tire to rub on the front of the wheel well? This has happened a few times now and has taken the paint off in this area. Sort of wondering if its due to running 10psi that the tire is bulging up in that area when jumping.
Azholley
17 AG, 21 IS, R pending
Peoria, Arizona
I only have rubbing in the front not the rear.
Bark beetle
Northern NM
No rubbing but the lowest pressure I have run is 30. 10 psi and jumping doesn't sound like a good idea, beadlocks or not. I am assuming you are running in the sand at those pressures.
Sent from my iPad using Tapatalk Pro
B
byz250f
thats correct...sand.
boomtruck
I have it rubbing there as well. 40 psi rough trails, air just once , but with a bit of payload.
It should clearance it's self soon. At least it won't rust! any bigger tires and it would be through the wheel well.
JetDriver480
I have a little rubbing in the front, aft wheel wells on tight turns. Nothing to make me want to cut anything yet.
Running 35x12.50R20 Toyo M/T's with 20x9 Wheels +1mm offset. I still love everything about the setup. Would maybe have stuck to 17's but wanted the 20's should I move up to 37's someday.
