How to pull 15 inch of travel on a budget.
gotsboost
kansas
Okay guys this was too good and works too good not to share. First here is the set up.
SVC bumps
Gen 2 3.0’s
Icons leafs setting 2
Camburg 1.5 shackles
Custom shock mount
Brake line drop bracket
So out of that the bump kit was the most but the truck works so good. The Shocks must be moved up about 3/4 of an inch so they don’t max. This is because of the bump kit allows more up travel. You must use a shackle too to achieve this as it lets the axle go forward allowing you to gain travel with a stockish shock.
NateMob
SATX
Nicely done, how much pressure do you run in your bumps and how much of the stroke are you regularly using?
98rangerdave
High Desert 92392
I know you said it before, but would the person who fabricated those upper shock mounts by willing to make another set and mail them to California? I can weld them on, I just need the pieces.
I’m basically running everything that you are, I am just running a GEN two rear shock on the stock mount.
98rangerdave
High Desert 92392
Any chance you could post more photos of that top mount? Like the sides and maybe some measurements? Gonna bend some 1/4” plate next weekend and try my hand at a similar setup.
PorterW1111
Florida
SVC bumps
Gen 2 3.0’s
Custom shock mount
If you arnt adjusting their lower shock mount as well I would highly recommend some limit straps. After moving the upper mount higher max droop will happen sooner. Depending on the relationship of the Deaver rate to the shock extension you potentially could excessively wear/damage the shock tube. I’d grab some limit straps and run them just to remove any risk of damaging the shocks.
My .2cents, awesome job I love seeing people push the limits and finding innovative ways to build these trucks.
gotsboost
gotsboost
kansas
I’ll ask. The problem is it was pretty custom the way we cut them.
gotsboost
gotsboost
kansas
I talked to SVC and icon. They both said the stock gen 2’s are designed to be maxed and hold
The weight of the axle. I got to say the SVC guys know their stuff
PorterW1111
Florida
Not doubting they have reason behind their statement. But a fully built race shock with much greater strength still has limit straps and bump stops for a reason. Save the expensive parts the wear and let the $50 strap take the beating.
93,171
56,440
jumpcutter
