coachhomer
- Joined
- Aug 19, 2013
- Posts
- 258
- Reaction score
- 100
theres a bunch of ball bearings inside with a retainer ring. i had to rebuild mine when i accidentally let it drop when changing my shock. but yes, they just stuff in there. dont forget to clean it all out and stuff it with lots of grease
yep. and dont forget to remove the brake line and 4wd vacuum hose. you will need to line it up before giving it a good shove to get it into placeSo if I remove the axle nut at the hub then it will just pull out? Thanks!
C
I should also mention that you do have to remove the shocks to remove the axles. That big lump of metal you see on the axle in the above picture will not go past the shock.
