ddubdb3
Sorry I don’t know the whole back story here. I’m just curious how much power and torque were you shooting for? Also did you look into the v8 swap waters?
Sounds about right for a 5th her pull at a 1.5 to 1trans ratioMorning,
Stage 4 CRP turbos and manifolds, AMS intake tubes kooks downpipes and AMS turbo flange. Whipple intercooler and AFE CAI. 170 stat.
Excellent install. Great shop. Dyno tuning with a tremendous effort. 37 pcm flashes. Can’t say enough good things about them.
The power is lackluster. Invested probably 12-14 grand. I don’t want to bother with the math at this point.
507 horsepower and 478 torque at the wheels. Heat soaked and 5th gear pull. It’ll make a little more peak on a cold run I assume... So basically nearly identical to MPT.
The whole thing was limited by knock on 93 octane. 4.5 of timing advance. Lambda a little rich at .77 on WOT but not way off.
Is it faster than bolt ons with a tune Yes. 447 on the same dyno. Is it noticeable? Some.
was it worth the money invested? No.
Is there a little more power in a hotter tune? Yes, but the power increases I think will be modest — and this shop tuned it for safety.
The dyno graphs from Five Star are not able to be reproduced - and no response from CRP as of yet.
At this point I can’t recommend these turbos and parts for the time and investment. If my opinion changes after some tune adjustments I’ll let you all know, but as of now this is where I stand.
I refuse to post the dyno plot as I’m just totally disappointed.
A pull in 4th or even 3rd would net better numbers -
I’ve done all the same mods an same results, an my turbos came from Ryan. Not worth the money
Ethanol or **** injection would help a lot but the goal was to try to get competitive with a TRX on pump gas.
not possible.
