vegascarnut
Henderson, NV
Installed new shocks, front and rear. Replaced the old Magnaflow exhaust with a Corsa. Rotors, pads (purchased through Freedom MotorSports) and hub actuator to be installed on Thursday. Also located the annoying squeak that I could of swore was coming from under the truck, passenger side. I was wrong, driver side tailgate latch was producing the squeak.
Do you drive this between washes? DAMN that's clean!
badm0t0rfinger
Rocket Man
The Beach
I say "finished" because I wasn't happy with the final fit and finish of the brackets that hold the top cover down... the top of the lid was sliding inwards towards the engine. I did follow the directions but I ended up pulling the small retaining tab and tacking on two little notches no bigger than about a quarter inch and then I ended up sliding thru the engine back and then using the supplied bolts.
