Kahuna
THE MORE YOU PLAY WITH IT, THE BIGGER IT GETS
- Joined
- Aug 31, 2014
- Posts
- 870
- Reaction score
- 794
Don't forget grease. Get a specific bushing grease like Energy is my view. Squeaks suck.
Are you running Icon or Deaver leafs? The cross member looks too close to the holes to fit Icons but tough to say from a pic. Call Jeff and ask him.
What torque is needed?
Lube her up!! Never go in dry!!
After some initial confusion about the SDHQ drop shackles it appears the SDHQ shackles made after Feb 2019 will work with Icon leafs!
Thanks Nick at Apollo Optics for all your help on this! Getting them installed soon [emoji3]
From memory 89lbs on both the eye to shackle and frame to shackle but I would ask SVC if I were you. I have seen other numbers floating around.
The Ford torque spec sheet shows 136 lbs.
