Finally did middle perch...now truck scrapes at 6'8"
Rat
Well-Known Member
under the 3rd st bridge
Options?
1. Eat more.
2. Teflon coat the garage door beam.
3. Sand bags to load down the truck coming in and going out.
4. Drive really fast (downforce will lower truck at least 1/8").
5. Rent concrete saw, remove 1/2" off of door frame (covertly, at night)
6. Paint door lintel same color as truck (paint will swap w/o color marking)
7. Anodize top of truck for wear resistance.
8. Grease truck top.
9. Air down tires to 15 psi for entry (takes forever).
Out of ideas.
Oh, return to stock perch.
That' really good Rep points !
or go with 33" tires, or lower it ?
Did you ever use a tape measure on the plastic tube then put your "go pro" on the roof and drive around to see how close you really are ?
Or I guess you could always do like "Oversize" ****** drivers and mount a pole on the front bumper about 1/2 " above your roof line and if that hits, you better hit the brakes ?
The world was not made for "RAPTORS"
Humvee21
That's why they're extinct
DEADEYE
MN
battery operated die grinder or sawzal . Better yet air powered die grinder as this would be a good excuse for the on board air compressor
Maxx2893
Rock and Roll Offroad
Burleson, TX
Slight lowering shackles in the rear to completely level plus lowers it some. This is what Tizzle has
SOCOMech
Famous Raptor
Phoenix AZ
Shouldn't have this problem in AZ.........So if anyone out here wants to have their perch mod done, don't be afraid to hit me up:Big Laugh:
