Budget Long Travel build (rebuilt bypasses and coilovers).
BlueOvalF22
Willow Springs, CA
I'm on used live valves for now but.... If you have patience, shock tools, and search race classifieds you can save a lot of money on a build by refreshing used bypasses and coil overs.
Rear end
Refreshed used deaver +3's
SVC Trac bars
SVC Bumpstop rack with king bumps
Before
Had a used bypass rack, didn't like the layout sold it.
Had 3.5 kings but sold for big $ during shock shortage when I sold my house in CA.
Now
Have RPG Chase Bypass rack coming in a couple days.
Have Pro eagle 3 ton and mount.
Have used, rebuilt, and re-valved 4 tube 3" by 17" bypass shocks off a race truck. (a bit under $1k). I compared the comp/ext dimensions to standard 16" fox and locating the perches to run these 17" won't be hard.
Front end
I found a used set of king 2.5x10 coil overs. (a bit under $1k)
Getting Springs... PAC 18" 700 psi main with a 6" 500psi tender.
Changing to f12/10 valving.
I will order Baja Kits LT when I have them done. I can do most of the installation if I have the coilovers
Searching for used 10" remote res bypass and hydro bumps.
06z
So Cal
Rear end
SVC Trac bars
Before
Now
Front end
We need updates with pics. I am Subscribed.
