Deleted member 12951
Yeah it's the LGE mounts and I bought them used off of a member here and he said he just rattle canned them.And I just bolted them on. If I was going to weld them on I would ask to weld the entire upper stock mount up since the factory put a full bead on the outside welds and only tacks the inside.
Yeah, I got to painting mine with a primer and two coats of paint then realized that they made them wrong. Called and a new guy started two weeks ago and did these. His welds are beautiful but wrong is wrong. Hoping Dale can get a corrected set out to me ASAP. See what what the new guy did?
---------- Post added at 08:21 PM ---------- Previous post was at 08:19 PM ----------
The moment the UPS dropped off the package of the single rotor and pads, I immediately went to work and got it installed before I lost daylight. Don't even ask how this got messed up....
BajaTaxi
IG @the_baja_taxi
Raeford, NC
Bought some deavers from the garage sale and realized the stock block and bump plate will be removed. So I started looking at bump plates....ended up buying complete Rogue Racing bump stop kit with King 2.5s. Pretty sure the pocket hole I have is large enough to get my hand through.
Fb73
France
You won't regret it, the Deaver are a huge improvement over stock !
Yukon Joe
Trafford, PA
Yesterday I checked the Moroso oil separator on my Raptor and found the can completely full at 3k miles, guess I need to check it sooner. The Moroso is catching over twice as much oil as the JLT that I had previously
Today I installed an Airaid SynthaMax #861-397 dry drop-in air filter and loaded a Livernois 91 octane performance tune. Been on the stock tune for the past 4 months due to taking my truck to the local ford dealership. Took the Raptor for a short drive to set the tune and put a smile on my face.
What do you notice that differs the two?
Why did you switch to begin with?
@Yukon Joe :baby: :baby:
www.runraptorrun.com
