Icon Springs on 3rd setting with MASSIVE rake ...
adllewis42
adllewis42
Seattle
I am running Icons and the New RPG drop shackle. No issues here at all.
I think that's likely where I'm going to go.
What configuration do you have your springs on, what's the weight in the bed, and what's the ride height?
lilgsx96
WA
I am running Icon stage 2 in the back with RPG drop shackles. Eibach pro spring up front. 42.0 in the front and 42.5 in the back with 200 pounds of crap back there.
Nick@Apollo-Optics
Is Camburg the only company that makes a stock length (non-lowering) shackle? I wonder why RPG don't seem to (or do they, and I just can't find them anywhere)?
RPG's billet shackles with fit Icon and Deaver springs. They have drop shackles and stock height shackles available. RPG's fabricated (non-billet shackles) will only fit stock or Deaver springs.
Camburg shackles will only fit stock or Deaver springs.
Ski4Ever
Denver, CO
So, you're saying that the only shackles that will fit ICON springs are either the stock Ford shackles, or the RPG billet shackles? Nobody else makes a shackle that works with ICON? Why is that? Seems strange to me!
On a related note...speaking of shackles, is there a benefit/drawback to running a 1" drop shackle rather than the stock length shackle? For example, say I want Deavers and want no lift. I could either do Deaver +2 with a stock length shackle, or Deaver +3 with a 1" drop shackle. What are the benefits/drawbacks of each setup?
tom wansor
new york
How do you like ride on road and off compared to stock?
Nick@Apollo-Optics
From our understanding, that's correct. RPG Billet is the only confirmed fitment. Camburg and SDHQ explicitly state on their site that they do not fit with Icon springs. And I confirmed the RPG Billet vs RPG fabricated shackle fitment with Icon yesterday for another client.
The reason is that the Icon and Deaver springs use a different style wrap at the ends where the shackles install.
As for running a Deaver +3 with a drop shackle:
Pro: Less sag during towing/hauling since you've got another inch of actual spring
Con: More expensive
Wojciech Gierczynski
Illinois
Replacing my Camburg Stock Lenght Shackles with RPG ones. Camburg stock length shackles with hit Icon leafs under compression. Ask me how I know. I was told by Camburg and SDHQ Offroad they will fit. Only after I emailed Camburg with photos as proof they changed description on their website that it wont work with Icon leafs. This is the pic how close Camburg Shackles are to Icon Leafs ... and this is while truck is parked with empty bed.
Illinois
Manufactures design parts around certain brands. When I talked to RPG, they told me their new billet shackles only would work with Deavers. Follow up with them.
That is crazy if nearly 800 lbs in your bed doesn't cause your springs to sag at all. How many miles do you have on the springs? I would make sure to get some miles on them to break in. Your sag should be similar to the figures in the picture because those figures came from ICON's website.
Well I just order these Stock Length Shackles from RPG and they told me they work perfectly fine with Icon's since they have more of the open design not like Camburgs shackle where there is a box under spring leaf.
Deleted member 17706
Keep rubbing it in that I was wrong why don’t you :)
When I talked to RPG, I was talking to them about my Gen 1, Deavers, and shackles—not about my Gen 2. The Gen 1 leaf springs are a different length than the Gen 2 leaf springs, so that is why they told me that the billet shackles would not work with the ICON leaf springs—only the Deavers. It is a non-issue on the Gen 2s, but is an issue for the Gen 1s. So sorry for the confusion. But as good measure, you should always talk to the manufacturer about what you plan on running because when you mix different brands, it is possible to run into issues.
I plan on going with Deavers and the RPG billet shackles on my Gen 2.
93,202
56,485
bjorn-dpc
