Upper/Lower Rear Shock Mount Reinforcement Plates
Discussion in 'Custom Truck Shop' started by customtruckshop, Feb 3, 2014.
  1. customtruckshop
    customtruckshop LGE-CTS Motorsports Supporting Member
    935
    256
    Mar 12, 2012
    San Dimas, CA
    We now have pictures of these MOUNTED!
    Upper Shock Mounts aka "Duck Plates":
    This rear upper shock mount reinforcement bracket or "Duck Plate" helps reinforce the factory shock mount from twisting or tearing loose.
    These work even if you have aftermarket shocks (ICON, Fox, ect....)
    This Upper Shock Mount is quick & simple for anyone to install. The bracket can be bolted or welded on. Hardware is included.
    The cost for a pair of these run $199.99. You can order these here.
    Lower Shock Reinforcement Plates:
    Our lower shock mount reinforcement plates help protect that factory shock mount from being bent or tearing loose when traveling in a rougher terrain
    These work even in you have after market shocks as well (ICON, Fox, ect...)
    From what i can see, these should not interfere with bumpstop systems as well.
    The cost for a pair of these run $249.00 You can order these here.
    You can purchase these as a pair (Both upper and lower mounts) for $400.00 and save $49.99! Please call (909)-599-2228 to order these together!
    Pictures of Upper Shock Mounts:
    [​IMG]
    [​IMG]
    [​IMG]
    Pictures of Lower Shock Mounts:
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Sigma Pi, ruffstuff and GBrown1867 like this.
  2. customtruckshop
    935
    256
    Mar 12, 2012
    San Dimas, CA
  3. Yukon Joe
    Yukon Joe FRF Addict
    42
    18,355
    11,596
    Nov 16, 2011
    Oak Island, NC
    With a $150 gift card to LGE / CTS you can get some shock reinforcement plates.
    Donate today and be entered into tonight's raffle.
    Donate to Avery and be entered into a raffle for an awesome prize for your Raptor.
    GPS Mount & $150 gift card from The Custom Truck Shop
    http://www.fordraptorforum.com/showthread.php?p=800805
  4. ramx50
    ramx50 Full Access Member
    594
    243
    May 21, 2013
    Wakefield, MA
    Does anyone on here have a set installed already?
    Any feedback if you do + or - ??
  5. Sigma Pi
    Sigma Pi Full Access Member
    40
    52
    Feb 3, 2015
    Los Angeles ish
    Do these bolt on or weld on?
  6. RDFTS
    RDFTS aka Rick Supporting Member
    13,361
    9,996
    Nov 10, 2013
    Southwest Missouri
    You can do either
    Sigma Pi likes this.
Share This Page
