GEN 1 Truck very unstable on one-sided pot holes
HORN HIGH ACES
Colorado
Nitto Trail Grappler M/T
35/12.50R17
40psi
Also noticed above the front shocks, there is a blue piece of metal that says: "ReadyLift Suspension Inc"
It appears to be this:
https://www.readylift.com/t6-billet-ford-raptor-svt-2-0-leveling-kit-blue-1.html
They put a leveling kit on, instead of moving the perch!!
Well, removing that is a place to start. I would recommend progressive rate springs (front and rear) to help mitigate the issues you're describing. They won't eliminate it, but there will be a noticeable improvement.
In the meantime, you may want to try 38psi on the Nitto's to see if that helps. I run my Toyo RTs at that pressure which improves the ride and so far the tread wear has been even.
Aaron
Meme Corps Commandant
WA
35/12.50R17
40psi
Ok so a few things here:
1) Get rid of that readylift spacer if you plan to get your truck into the dirt. Full droop with that spacer in will be more than your control arms are designed for which can damage things.
2) With that spacer in, if you're on bottom perch the ride should be pretty plush and 'roly poly' like. It should soak up most things without feeling unsafe like you said.
3) because of #2, I'd say you need to get your shocks rebuilt and at the same time you can do #1 and also have them set to mid-perch.
4) You could also add the Geiser progressive springs that UTV inc sells. Lots of guys run those and love them.
My truck feels really stable and planted on the road and I'm running stock shocks/springs all the way around. A rebuild is your lowest cost option to try to remedy the situation.
GPD
I am going to have them rebuilt through the shock exchange, and set mid perch. Once I get them in the mail, and pull the old ones, I'll get rid of that spacer. I'm going with stock rebuilds at mid perch, with schrader valves.
Glad to hear your truck feels planted. I'll report back if this fixes my problem.
Thanks all.
Huck
Chicago Sw Burbs
Pull that ready lift shit first. And check for any other suspension modifications
Once you get it pulled get an alignment before you send your shocks in.
Right now the geometry is jacked so the suspension is binding on every bump. That's why your getting chucked everywhere.
BAD454SS
Banned
HELL Arizona 6.2L There is more to life
Spacer did that to my truck early on, plus blown shocks and a whipple .Very scarry to drive. Suspension geometry is out of wack with those spacers. I went to icon 3.0 and icon upper control arms. Truck drives like its on rails now on and offroad.
K
KingRoman
Thanks all.
Hey. OP here.
My shocks were toast and I bought the truck with only 17k miles on it. The truck was in mint condition but the previous owner must of hucked it or something lol. I waited a while to rebuild mine because I couldnt fathom how they would be dead at 17k.
Anyway, drove down to vegas and had Walter rebuild them. Truck feels great now. Planted and stable.
Like others said that spacer up front is probably causing issues too. But once you get the new shocks in im sure it will ride great. Mid perch helps the bump steer issues on the highway too.
Good luck and enjoy
