GEN 2 Rogue, ADD, Deaver, RPG, Fox 3.0 shock upgrade Intial Review
S
Stickman89
Nw Indiana
that's kinda sketchy that the tie rods rub at full lock. did you buy everything as a kit from rogue or rpg?
It's minimal tie Rods move up and down with everything. By like a 1/16 they come in contact with shock base at full lock. Rogue is looking into it as we speak. Nobody had these shocks available when other parts were coming out.
Tex7432
a hole in the wall town in what is now called Idah
gotcha. hope they get it sorted out for you!
great write up!!! depending on ur caster numbers you might be able to take a little caster out to gain a little clearance for the larger tie rods. Thats a maybe though.
@khcdave Bravo!
@Stickman, your tierod is on backwards. :console:
Working on a completely application based kit for the 2017.
Yall are running generic 2015 4x4 wider parts from factory.
** Hope this was fixed by now, was looking around FRF finally.
[email protected]
Booth9999
Idyllwild
So..... what was the outcome? Did you get the tierod to shock contact resolved? Is here a update tierod? Does the RPG tierod have the same problem?
agobel83
Denver, Colorado
Did you get the tie rods figured out? I just bought the same ones and am running them with the Fox 3.0 and Camburg Kinetik UCA.
Also curious on your suspension settings. I Feel like I have my fronts figured out, but just put on the Bypass rears and have not made any adjustments.
joey185
I just did 37's 3 weeks ago and they are coming off today. 2.25 inch RPG in front with cutting and still get a little rub on drivers side but also made truck very sluggish.
TXRaptor
Did you also do a tune?
My truck is in the shop right now getting 37s and an MPT tune, so I am hoping the tune will outweigh the larger diameter and heavier tires.
joey185
dateposted-public
No tune
