CptMorgan
I have a custom performance tune from Mike @ 5 star.
I've been playing around with data logging with Dash Command.
It appears that the motor has a fuel cutoff at exactly 6000 RPM. Then there is a true hard wall rev limiter at 6250 RPM.
It's hard to tell with a simple data logger (not Dyno), but the motor appears to still be increasing power right up to the 6000 RPM fuel cutoff. Calculated HP and fuel rates are still increasing up to the 6000 RPM cut off....
Question, can I raise the fuel cutoff point with the X3 tuner myself? There is only one option labeled "rev limiter"
Are others with mild mods still pumping fuel beyond 6000 RPM?
