whtrapta
Ostrich Wrangler
I've had all 4 of my wheels spin forward and back in 4HI in the snow and ice. Never engaged 4LO yet.
Yup - you got an issue YMP. I had to play with all 4wd options today just to get outta the driveway.
You should have had at least one wheel peel in the front end - whether you were in low or high.
Now, given your conditions bein snow covered - is it possibly the hubs froze and couldn't engage? That's happened to me once or twice this winter.
Keep us posted - mine's going in on Monday to check the lefr front hub as I'm getting noise there indicative of a stripped hub gear.
"Ill need to take it to a place and have it fully lifted and then have them engage the 4 wheel drive. high Low forward and reverse locked un locked and see what happens..
very strange, i was in 4 wheel drive low, got stuck, pulled the switch to lock it in, put it in reverse and only the rear spun. The dash said I was locked. they spun forward in drive. I know I wouldnt have walked 6 miles...
Are you talking about your ELD (Electronic locking differential) thats how I understand it the ELD only locks the rear tires together the front differential is still open diff and will spin the tire with least resistance. I would guess if your driver front tire wasn't spinning then the passenger front prob was just by a guess but it neither tire was spinning then it would sound like 4x4 issue.Correct me if I'm wrong but sounds like you were thinking the front tires should be locked like the rear should.?
Come to think of it, your right . I was looking out at my driver front tire and it was not spinning.. I guess I was thinking that when it was locked it would lock the front and rear.. (my 700 grizzle atv has that feature and i was thinking the Ford ELD locked everything)
I need to ask my buddy who was with me if the passenger was spinning. Im sure it was...
I was stressing at the time because i was stuck miles from civilization. Sounds like I cant blame this on the truck.. I believe it may have been the indian not the arrow. Doh!
