AZ SVT
Next time, try this.
WARNING: It is very important that all wheel spin is stopped in a controlled manner. Slamming on the breaks or even abruptly lifting off the gas with the wheels spinning is the quickest way I know to break an axle!
From JP7-...make sure the damn ORM is on and the Trac Loc is completely off!
- With the trans in gear (D or R) and the transfer case in 4x4 Low (or high)
- Take your foot off the gas and carefully stop all wheel spin
- Press hard on the break
- Bring up the engine RPM up to about 2000 - 2500 RPM (still mashing on the break)
- Now slowly let off some break pressure (you should be driving with both feet) until the truck starts to pull out. Speed should be controlled by the break NOT THE GAS
- Continue to modulate throttle and break to control wheel spin and maintain slow, steady movement
- If there is any traction you should be able to pull right out.
- If your are hopelessly high centered (no traction at all) call a guy with a old Chevy!
