- Joined
- Dec 16, 2016
- Posts
- 16,331
- Reaction score
- 24,101
So, you got the oil warning light and limp mode, didn’t check the oil, got to where you were going and did check the oil?
You’re assuming that 2 occurrences are related where both are simply unrelated facts.
Running the pedal commander has nothing to do with being low on engine oil. While it’s possible to screw up the p/c install and de-install, this does not appear to be that.
You have symptoms that include running a pedal commander, going heavy on the throttle, limp mode and low oil warning light. Subsequently you verified you were running with low oil. Limp mode is designed to save the engine from catastrophic damage in conditions like low oil. While this is not a scientifically sound analysis, at an evidentiary level, it is exceedingly likely that your low on oil condition caused the malfunction indicator lamp. There are 2 issues paths here, short term remediation and long term fix.
1) short term remediation - add sufficient and correct oil.
2) advise dealer you had the check engine light. I would not involve the pedal commander in this discussion and for the purpose of said dealer visit I would not have a pedal commander with me. They will likely want to monitor oil, however, there is a TSB from Ford that replaces the valve covers, I believe it’s due to the original design and gasket allowing oil to be ingested via the valve train.
