The hot rod cams are engineered to idle much more aggressively than their size would suggest, so that is definitely a big portion on the rocking. As far as the pushing, the new 6-speed does have a much tighter converter than the older 4-speed autos had, so pushing at idle is much more apparent. We don't really recommend going with a full stall converter for the raptor as most of the aftermarket units will be set up for a light weight mustang, not a heavy truck, so they will stall far too high. I would modify the stock one to get another 3-400 rpm out of it personally.
