Clunky Eibachs- Sanity Check Needed
Discussion in 'Ford Raptor Suspension Discussion and Modification' started by LF2020, Jan 11, 2020.
  1. alcoolaid
    alcoolaid Full Access Member
    71
    61
    Mar 4, 2019
    Vancouver, BC
    Mine made lots of noises when the shocks were topping out over bumps. After a few weeks of driving it’s much better now. Let them break in and enjoy :)
  2. LF2020
    LF2020 Member
    6
    Jan 11, 2020
    Orange County, CA
    You’re saying all the right things to back me off the ledge. I appreaciate the feedback.
  3. PlaynCA
    PlaynCA Member
    25
    17
    Sep 11, 2019
    los Angeles
    Mine made a noise at top out not long after Eibach install, front wheels were off the ground after dip, but it wasn’t excessively loud or harsh, hasn’t done it since.
    The lower shock mount ( to LCA) is supposed to be 406 lb ft. If not tight enough, I would think that could cause noise...if that is the problem, might be able to see some marks on the shock mount or LCA if it is moving. I used a torque wrench and torque multiplier to reach spec, not sure how shops normally torque that bolt.
  4. GLOCK26
    GLOCK26 Full Access Member
    50
    12
    Oct 28, 2019
    El Centro,CA.
    I have eibachs also and hear the same noise when going over speed bumps.
  5. SCMike
    SCMike Full Access Member
    120
    57
    Sep 29, 2019
    San Clemente
    I experienced the same thing when I installed Eibachs on my 19. After a month or so and 1-2k miles, they totally settled in and I no longer have this issue. Seems they just need a little time to break in. Best thing to do is just go out and run them hard off road for a day or two
Share This Page
