Beauty Ring Torque Specs?
Discussion in 'Ford Raptor Maintenance Forum' started by dblack, Dec 29, 2019.
Car Parts
  1. Erjdrvr
    Erjdrvr Full Access Member
    54
    16
    Dec 10, 2018
    Indy
    Ok, the original question was about Gen 2 bead lock capable rims. Again on my 18 the factory beauty ring bolts had yellow/white thread lock from the factory. I used blue thread lock when I reinstalled the bolts. I loosened the bolts on one rim yesterday and had no seized bolts. The bolts had been in for about 6 months & maybe 5k miles. See pic below.
    I plan to remove the rest of the bolts in a few days to have the beauty rings power coated so if I have any additional problems I'll update the post.
    Also I'll make a note of the torque as well.
    I've seen plenty of debate on whether the Gen 2 beauty rings must be removed when changing the tires. I had 2 sets of KM3'S installed on these rims. First installation was on the OEM painted rings & I noticed no scratches. But before the 2nd installation I painted the beauty rings with Rust-Oleum Peel Coat & I did notice some damage from the 2nd tire install.
    Anyway I've reviewed the Raptor Supplement regarding info on mounting tires / beauty rings and found nothing. If anyone has official documentation regarding the tire mounting & Gen 2 beauty rings that would be great![​IMG]
    Sent from my SM-N960U using Tapatalk
  2. dblack
    dblack Full Access Member
    104
    68
    Sep 15, 2019
    Alabama
  3. dblack
    104
    68
    Sep 15, 2019
    Alabama
    xtela and Erjdrvr like this.
  4. dreuter
    dreuter Member
    36
    8
    Nov 4, 2015
    [​IMG]
  5. HotLap
    HotLap Full Access Member
    396
    146
    Mar 7, 2018
    SoCal
    Perfect, was trying to find out if the trim rings were to be removed or left on for a tire change. Picked up a screw right in the center tread and going to have to take into tire shop for repair/replacement. And rather than have the trim ring bolts over torqued/stripped, I'll remove/reinstall myself...
    JohnC12 likes this.
  6. JohnC12
    JohnC12 Full Access Member
    211
    107
    Mar 3, 2019
    Leesburg, VA
    Brilliant idea!
  7. txgunsntrucks
    txgunsntrucks Full Access Member
    108
    26
    Jan 18, 2020
    texas
    locktite!? Yeah try that shit and see what happens.
    Just another thing being made into a problem that isn't a problem at all
    tighten that shit until snug. end of story
  8. txgunsntrucks
    108
    26
    Jan 18, 2020
    texas
    do you really know what that ring is for?
    whole point is keeping the tire on the rim when the air is low. so yeah, would make changing the tire kind of difficult
  9. melvimbe
    melvimbe Full Access Member
    1,100
    793
    Jul 22, 2019
    The question was about the beauty rings, which don't hold the tire or provide any other function other than cover up the bolt holes available if you do opt for bead locks. Given that it is a great idea to remove the rings yourself if you don't trust the tire shop to do it without scratching them.
  10. txgunsntrucks
    108
    26
    Jan 18, 2020
    texas
    so still pretty dumb to locktite or try to not remove and still do a tire change.
    take off yourself. when putting on tighten until snug. easy right?
Share This Page
