Another sub question
Steve Parker
Indiana
I have read several posts thus far and it seems like there are a few different ways to switch the existing sub. Everything from dumping the b&O amp, adding a zen, adding one or two amps, adding 1 or more subs.... it also looks like it is equally possible to tap the front line before the pillar tweet, running it back to a Lc2 and then to a new amp and new sub (disconnecting old sub and removing box). If this is correct, I assume there wouldn’t be any roll off on the new sub as the b&o does, and the Lc2 would receive the full frequency spectrum, correct?
The Car Stereo Company
aka grumpy car stereo guy
here, on frf
no matter what you do, the oem signal will retain the factory eq curve. adding the correct components will reduce the amount it is affected.
