Ruger
Northern Nevada
Installed four Eagle Eyes 1.5 watt LEDs in the lower grill to be used as DRLs.
oplersx
British Columbia
Installed the fogs tonight. They ALMOST fit. Almost being the operative word.
The inside lights fit fine, but the outside lights are just 1/4" too big for the opening and the Rigid Bracket, so they push up a bit. Enough that lighting them up would be a hazard.
So unless I find some creative way to either make the bumper hole bigger or the light casing smaller, I think I'm going to wire the inside lights only for now. But I definitely like the round look a lot more.
Do you have a photo shows how does the rigid mount mounts? I can't figure that part out:eek:
ZBoater
No. It mounts with 4 screws to the frame. You have to drill 4 holes. And the 3/16" holes for the self tapping screws are too small. They should be more like 1/4". The screws are 5/16".
There is s section of frame visible right behind and above the bumper openings.
Wilson
South Dakota
Can you switch them side for side? Bracket will be the other way bit will be back if it fits.
oplersx
British Columbia
Thanks! I thought they are bolt on...
HAYNES OFFROAD
aka Wreckless
Bourbonnais, IL
Just testing out some new "gear". Just a prototype for now....
