Rough Country LED Ditch Lights
RaptorGhost
Miami, FL
So I bought these Rough Country ditch lights and went to install them on my AUX 2 but the harness is a mess, and not specifically made for Raptors.
Link to the lights
That being said, is there another harness or something that I can buy to make these lights connect to the upfitter switches? Harness is shown in the link provided.
Also, is there a good "splicing" video that will show me how I can connect to the green/brown wire? Unable to wrap my head around it lol
Sig Fanboy
WV
I got same lights. Mount the relay, ground black wire to body, hook red wire to positive battery. Unplug switch, throw in trash, cut white plastic plug off, run blue or red to any single upfitter wire, forget about other two wires.
Sig Fanboy
WV
Do yourself a favor. At least use a male to female connector to hook to upfitter switch, not a but splice. Given some engineer decided 4in of wire… and hey let’s stick them behind the battery, cause that’s super inconvenient… was the correct amount . If you are like me and change you mind a lot, you won’t wanna keep cutting off butt splices. There are better methods, but if you are like me, you ain’t gonna wait for more parts to come in before you hook them up. I bought a huge assortment of weather pak connectors and crimping pliers and release tools from Amazon, they are made from the finest Chinezium, but do the job.
aka grumpy car stereo guy
Sig Fanboy
WV
Very nice and very helpful, especially how to correctly use the pliers for the Deutz(?)( I’m sure I screwed that up) connectors .
RaptorGhost
RaptorGhost
Miami, FL
Thanks for this. I'll be trying it out this weekend.
RaptorGhost
RaptorGhost
Miami, FL
Great write-up. Needed this to better visualize what I'm going to be doing. Thanks.
Sig Fanboy
WV
I have lights from RC, Rigid and BD. All the switched harnesses are essentially the same. I checked the RC lights, the blue wire on leg that goes to switch is all you need to hook to upfitter wire.
I didn’t order the A pillar kit, just the lights. I have A pillar mounts from SDHQ. I ran the wiring under the windshield wiper cowling. I found good videos for a Gen 2, I don’t know how different a Gen 3. I have my light pointed at about a 45 degree angle from centerline of hood. The light wash on the hood is somewhat distracting. Possible yellow lights would be a better choice. I think the A pillar lights are more cosmetic than useful actually, but I have 4-6.5 lights, a 20in light bar and 2 yellow fogs on the front,I’m lighting up every zone pretty well without the A pillar lights.
I have 4 relays mounted on top of fuse panel lid and one relay out near the battery, finding a good mounting location for all the relays is a challenge.
Nex
RIP CoronaRaptor
Washington State
Add these to the short uplifter wires.
This for the lights to the a-pillars
RaptorGhost
RaptorGhost
Miami, FL
Thanks a lot again. I did exactly what you said and used the blue wire on that harness and ignored the others. The lights came out awesome and pain free.
