Alternative High-Beam Connection ?
FordTechOne
Detroit
Have Diode Dynamics SS3 max driving pods and used the blue switch wire of the relay harness tapped into the high beam wire of the Starkey Products headlight adapter harness. Seems to work perfectly, ran Forscan and showed no DTCs. To be safe should I replace the standard relay with the Hella solid state relay?
Solid state would be the safest bet, the amperage draw may be on the threshold of setting a DTC, but you'll never know if one sets unless you're checking it on a regular basis. Which certainly isn't practical.
toledoUPSguy
haskins, OH
Thank you. Apparently even though the plugs are the same the hella solid state relay does not function the same as a Bosch style. Do you know of one that does?
DFS
USA
This is an interesting concept, and I hope that something pan's out for the OP. But seems like a non issue to me, you can literally flip a auxiliary switch with next to zero effort and no risk of interfering with factory settings etc?
2020Raptor
2020Raptor
South Central...NJ
I find that I want the aux lights whenever the high beams are on.
Repeatedly reaching up 30 times a trip to turn on/off to allow for oncoming traffic gets tiresome.
Now that the nights are longer, I need to get back into this.
There is not as much need in the long summer days.
aka grumpy car stereo guy
only question is why the attached PDF from lingentelter says they aren't interchangeable?
they say that you will need to change the wiring. however, 85 and 86 are interchangeable with a spst/spdt relay. maybe the ss relay is power directional. but 87 and 30 shouldnt matter as the relay connects those 2 pins upon activation
