Bozz
Royal Smart A$$
That or ham. I like the Baofeng uhf/vhf.PRS radios?
Hey Oldfart...why do you post things like this?? You continually crack me up. I’m not certain I can take much more...
3. flashlight
Tire plug kit
An EPC, Emergency Portable Companion
A manual pump does not take up much room.
Unless you’re in the middle of nowhere, there’s usually a pudgy humanoid that can’t outrun you... unless you are that pudgy humanoid - in that case, don’t off road with me, because if push comes to shove, you are a potential food source.A couple of MRE's would be a good addition
If you’re keeping the light or any other battery powered accessory in the truck all the time, accelerate your battery replacement schedule. The heat of the cab will wear them out a lot faster; co-witness optics are a great idea here, and spare batteries for what you have in the truck, just in case.
excellent idea. see below.
I like where you’re going with this. Is your EPC multi-use?
+1. I have a VIAIR (?) that’s rated for 33” but works just fine for me. from 20-36 or so in about 5 minutes and will do all 4 tires just fine. Gets HOT as F***, but works.
WHAT? @Oldfart gets away with way worse.
in addition to tire plug kit: Basic wrench, sockets, 2 drivers, swivel head, extensions, BFH, pipe / breaker bar, pliers & blow torch, gorilla tape, zip ties, screw drivers, torx bits, hex heads, etc.
This weekend, I took the wife out to Texas W(h)ine country. They’re not joking about it, I’ll bet they have 100 wineries crammed into Frednecksburg alone... Anyway, she had this one as a destination so we get there and I park us next to this peasant in his peasant 7 series. Normally I wouldn’t, but the only other open spot was a little tight for Lucille. She is just big framed... This poor bloke - prior service - has a flat. I ask if he just need air, hook him up, and his ‘must be $300+’ F1 is pissing out air as fast as my compressor is filling it. Upon inspection it’s a 3/8” head screw in his tire and it’s totally deflated. It gets worse - he has no jack, no tire iron, nothing.
I had just pulled out my tool bag and not put it back into the truck for this trip. First, i was just frustrated trying to help this bloke out, but then this feeling of cold numbness overtook me because I realized it could’ve been me. This guy was a fellow vet - and poor car choice aside, him and his guests were stuck. so we dug around and eventually scored a jack, but before he gets the car up I stop him - you should break loose the lug nuts first- only he doesn’t have a wrench, socket nothing so we have to scrounge other guests at the winery to get one. eventually one of the guys who works there has a the tools to get the wheel off. I offered what I could, but damnit I had tools to help this guy in my truck and took them out to go pick stuff up from a store and was just too lazy to put them back. Lesson learned.
Looking for ideas to fill out my EDC setup in my Raptor. I have some extra room in the molle pouches I've installed. Here are the ground rules:
1. I am not concerned with theft. I'm looking for ideas on helpful items I should EDC--not reasons I should refrain from EDC because it might get stolen one day.
2. Weapons are taken care of, secured, and not addressed in this post.
What I have so far:
1. Complete trauma kit (two bags on underside of rear seat)
2. ratchet straps
3. flashlight
4. Gerber multi-tool
5. pens and sharpies
6. gallon ziplocs
7. gloves
8. shop rag
9. wet wipes
10. IPA wipes
11. trash bag (lower left on back of passenger seat)
12. Gerber shard
13. emergency blanket
14. emergency whistle
15. life straw
16. LED light for quick use when searching through bags (hanging from tab on upper right of passenger seat)
Things I know I need/want:
1. Jumper cables (likely stored elsewhere)
2. ...?
So what have I overlooked? Thoughts, ideas...?
View attachment 153149 View attachment 153150
