Does anyone make a limit strap kit frt or rear?
Loufish
Burbank CA
Looking to see if there is a quality kit for limit straps?....really thinking about the rear with the heavy rear axle hanging off our shocks at full droop...
Loufish
Loufish
Burbank CA
Not sure a limiter is needed... Pretty sure the springs perform the function.
That may be but I now have Deavers and longer shackles which will droop at least 2 mores inches if allowed...
khcdave
South Brunswick NJ
Here is a strap kit I put together for a build we are working on. Keep in mind this is a long travel set up that needs limiting. Rear frame brackets bolt on to factory holes and tabs weld to the rear axle. For the front its a bolt on frame bracket that mounts an adjustable clevis mount- the lower has a tab that bolts to the shock bolt.
The shocks are the limiters for droop so straps are never a bad idea- but not always needed
Turbogoat324
SoCal
Are they adjustable so they can be used on stock suspension travel? IE stock shocks with deavers?
93,180
56,460
khunter
