Hp Limit?
Alaskan Assassin
Reston VA for now
Does anyone know the HP cap for these engines (6.2L)? I had an 04 Lightning and was told you could boost it only up to about 450ish without re-doing the engine. I am not very versed in this department, help would be appreciated...
Droid
kglesq's Brother
Not that this is a good measuring stick, but Hennessey has a 600 hp twin turbo Raptor that uses stock internals.
Can agree with that. :D
Raptor XT is supposed to be 500hp (crank) on stock internals, naturally aspirated. Forget what they do, I want to say ECM (of course), cams, injectors, exhaust. Not street legal though.
SOCOMech
Famous Raptor
Phoenix AZ
The R was slightly underrated at 500hp w/ cams, ported heads and TB, along with the obvious intake, long tubes and exhaust and tuning. I think it may have had a slight bump in compression as well. The XT has always been said to have the same 500hp figure but I believe when the time comes, it will only be 485 or so for pump gas reasons.
iceman302
Full Throttle OG
El Dorado Hills, CA
I think the 6.2 should take to a supercharger fairly well. The compression ratio (9.8:1 I believe) is reasonable for a small amount (7-8 lbs.) of intercooled boost.
speed45
Hey, I just bought a Raptor and Im also a Ford employee (Auto Technician). You dont wanna go more then about 500hp on a 6.2. Thats about all it can handle reliably, adding boost to the engine or increasing hp past that can make things questionable.
SilverBolt
Hired Gun
Portland, OR & Eureka, MT
Welcome. Are the rods the weak link once again? Why Ford even put powder forged rods in the Lightning I will never understand. My bet is they are in the 6.2 as well.
