Building an Off Road Toolbox
McGrath4u
Thanks Truckzor! I was looking for one made by Curt, but I couldn't find it! Do you know if they sell the Shackle individually as well? I'd like to have two.
McGrath do you have a recommendation on the tow strap as well that is American made, or one you have experience with that has proven itself?
For dynamic recoveries (snatch) use Bubba Rope or Southeast Overland brand kinetic recovery ropes and soft shackles. For static (just pulling without a running start) I like to use an oversized (3") strap from whomever as the risk is lower. I currently have a rugged ridge but ARB, USA cargo control would be good options.
hkguns
I'm putting my recovery / stuff kit together. Here is what i have so far, does anyone see any huge mistakes?
I'm storing all of this in a Condor Colossus Duffle Bag Olive Drab.
- BaoFeng UV-82HP High Power Dual Band Radio: 136-174mhz (VHF) 400-520mhz (UHF)
- ThruNite® MINI TN30 LED Flashlight: Max Output 3660 ANSI Lumen
- Leather Gloves
- Bungee Cord assortment
- Ontario Machete
- Rubber Mallet
- 10X Cyalume SnapLight Industrial Grade Light Sticks, Green, 6" Long, 12 Hour Duration
- Bond LH015 Mini D Handle Shovel
- Self-Fusing Emergency Repair Tape
- Olive Drab Green Warm Wool Fire Retardant Blanket
- ARB ARB730LB 3" x 10' Tree Saver Strap - 26500 lbs Capacity
- ARB ARB220 Orange Recovery Damper
- 2X Bubba Rope Green & Black GatorJaw 7/16 Soft Shackle
- CURT 45824 Tow Strap 2" Ball Mount
- Smittybilt 2744 Universal Snatch Block
- ARB ARB705 2-3/8" x 30' Recovery Strap - 17500 lbs Capacity
- Master Lock 1465DAT Stainless Steel Barrel Head Hitch Pin
- Smittybilt 13047B 3/4" Black bow shackles
- Hi-Lift Jack HL604 60" Hi-Lift Black Cast and Steel Jack
- 2X Wavian USA NATO Jerry Fuel Can and Spout System Black (20 Litre)
- ARB 10000010 Orange Speedy Seal Tire Repair Kit
- Q Industries MV50 SuperFlow High-Volume 12-Volt Air Compressor
- ARB ARB505 E-Z Deflator
- 3/8" Drive socket with recommended Metric sockets
- Pliers - Channel Locks - Pipe Wrench -
- Warn Winch 90360 ZEON 10-S Multi-Mount Winch Kit
- Micro-Start XP-10
- Separate Medical supply kit complete with SERE gear, fire starting, H2O treatment etc.
Doc Constantine
SoCal
- ThruNite® TN12 EDC LED Flashlight: Max Output 1050 ANSI Lumen
- Leather Gloves
- Ontario Machete
- Rubber Mallet
- Smittybilt 13047B 3/4" Black D-Ring
- Separate Medical supply kit complete with SERE gear fire starting H2O treatment etc.
For raptors I believe we use the ARB710. I've seen a lot of trash talk about the smittybilt stuff, mainly b/c it's made in china. Also, you want bow shackles, not D-ring, I know some ppl use the terms interchangeably, not sure if that's the case here. I see a hitch pin but not recovery hitch listed, are you going to pull off the pin? Recoveries aren't always a straight pull.
I have the ARB710, the gatorjaws, and a bubba they've all worked well in several minor (and one more involved) recoveries.
hkguns
Can you post a link to a shackle? I'm pretty sure what I have are actually shackles.
Recovery hitch is the Curt product in the list above.
Thanks for your feedback.
Doc Constantine
SoCal
Missed it! The pic I found on google of the curt 45824 has an orange bow shackle attached.
hkguns
Thanks, the one in the Curt is the same as the other shackles. Thanks for the heads up on SB and China, didn't know that one.
Yukon Joe
Trafford, PA
- Leather Gloves
- Ontario Machete
- Rubber Mallet
For the snatch block, I would go with either Master Pull or Warn epic . I have 4 snatch blocks, and those two stand out by far.
http://www.southeastoverland.com/in...ct_id=192&virtuemart_category_id=17&Itemid=33
http://www.morris4x4center.com/warn...DT7CIfGdkiA0b9brFWWraOVmLhCl4gLEeQaAolO8P8HAQ
If you carry at least 3 snatch blocks you can winch yourself backwards.
@Yukon Joe + @RaptorWifey = :baby: :baby : :baby:
2012 Night Raptor wrap SCREW RPG Stage 4+
2014 Ruby Red SCAB
hkguns
Winch Line Blocks : Master Pull Snatch Block SBO30000 | Southeast Overland
Warn Epic Snatch Block - 9.6" Long - W93195
@Yukon Joe + @RaptorWifey = :baby: :baby : :baby;
2014 Ruby Red SCAB
Thanks for the tip. Looks like I'll be scrapping the POS SB.
