Wiz's Build
wiz1500
wiz1500
Why 12qt of Power Steering?
Customers
Why the new shifter? So you won't have T/H mode or manual mode? What about the 6 gears in the trans? Your shifter only shows 4 gears?
And pardon my ignorance on the above questions, just curious.
2010s don't have manual mode so no loss there. Mapping for 4 will be drive most likely every thing else mapping to its original position.
Correct.. The T/H button has been moved to the console top and everything else will function as normal. The MAJOR advantage in this shifter is you can hit it as hard as you want and it will only move one gear at a time...This for me is a big deal. I would very often over shift the truck when the going got ruff and fast...It's difficult for me to gingerly try to make a gear change in those conditions.... Top 5 mod of all time on my truck..
beemerman
Worlds most famous beach
I used to run a hurst vertical gate shifter in my nova back in the seventies. You could just slam the gears and not worry about missing a shift. Ask me how I know lol. Scattered the engine on my First 1/4 mile pass on the car. Missed a shift when the engine torqued over went from second back to first.
Raptized
Raptorida
Wiz, great build. Someone mentioned you had some under vent or side vent leds installed. Got any pics?
Sent from my SAMSUNG-SM-N900A using Tapatalk
