water in the front diff !!!!!??
Mikexr1
Mikexr1
Germany
ok also good to know,,,but this is why we are taught to PMCS everything in the military,
" preventative maintenance checks and services " a system that allows you to find faults on your vehicle before it turns into a major problem......as I said before I do this with my own vehicles and it has saved me many times, but for this case I caught this issue before any big problems down the line happened with this torsen diff ..$$$...but thank you to everyone for your input, and one spot that makes sense to me at this point is the fitting for the vacuum line...so that's the plan...
Wilson
South Dakota
other thing if you replaced your oil and still had some in. When they refill it it will over fill if they put in the spec amount.
Boss Hoss
Colleyville, Texas
The breather tubes are prone to leaking where it connects to the diff and could also suck in water at that point.
Yes got my front diff and the rear polluted on my last Dodge oil burner by driving through a flooded (foot deep) hwy for about 30 miles. Went in through the vents---one of the first things I do on my vehicles is route the vent tubes to the gas filler tube level.
Madcowranch
Genetically Modified
OK
I know I'm a skeptic but my first thought is a crooked shop trying to sell unneeded services.
nsdq3
West Point, VA
How do you "spot check" the diffs? I thought it was either crack the seal and let it drain or leave it alone. Even if you just crack it enough to get some fluid out the tighten it back up you are still ruining the gasket/seal, right?
Wilson
South Dakota
your thinking tranny oil.
