starting out by saying hello to everyone here... just joined the forum...
ok so long story short, wife took in the raptor to a local shop for an oil change, im deployed in Afghanistan right now and my primary jobs are truck repair/ recovery....anyway.. the guys at the shop opened up the front, rear, diffs and transfer to spot check fluids, well the front diff was FULL OF WATER!!!, the truck has 15,000 miles on it and the last oil change inspection was done at 12,000..and at that time no water...so first off check the vacuum line to the front diff, it WAS connected and no damage to the line, and neither the input seal or both out put seals showed any signs of leaking, fill and drain plug where also tight,,,,we had the fluid changed out and flushed at the local ford dealer, they couldn't find any reason y this happened...and since then once a week she stops in just to have it checked ,and after heavy rain falls as well.... all is fine..!!!
so how the hell does a half a gallon of water end up in the front diff?????? anyone??
