Help SupportFord Raptor Forum by donating:
Help support Ford Raptor Forum :
Trying to adjust stuck (possible corrosion) lower perch
Discussion in 'Ford Raptor Suspension Discussion and Modification' started by Spectre338, Mar 30, 2019.
Sponsored By: Fox - Redefining Ride Dynamics
  1. Spectre338
    Spectre338 Member
    Mar 30, 2019
    Arizona
    I got a new to me Raptor Last week and would like to level it. I was able to adjust the perch on the drives side but noticed some corrosion. On the passenger side, the lower perch won't move at all, I assume it is also corroded. Does anyone have advice as to how to move a stuck perch?
    RPG likes this.
  2. EricM
    EricM FRF Addict
    1,467
    871
    May 11, 2016
    Cincinnati, OH
    Hit it harder.
  3. RPG
    RPG Supporting Vendor Supporting Vendor
    2,007
    2,354
    Mar 12, 2011
    Orange County
    Do you have any wd40 or pb blaster? Something to spray on it and dissolve it..
  4. Spectre338
    Spectre338 Member
    Mar 30, 2019
    Arizona
    I have soaked aked it in WD-40, will try PB next
  5. ogdobber
    ogdobber Full Access Member
    800
    735
    Feb 9, 2017
    I assume you've backed out the set screw...
    Lime-away is the ticket. Its not so much "corrosion" but a build up of sediment
  6. naimad
    naimad Full Access Member
    108
    12
    Feb 9, 2012
    So Cal
  7. mpk1996
    mpk1996 Full Access Member
    123
    49
    Mar 5, 2013
    if you have to, remove the shock and spring assembly. then remove the spring. make sure the set screw is loose. with the spring off it, and out of the truck you should be able to hit it harder with a dead blow hammer.
    but first try the pb blaster or lime away. make sure to get it in the top and bottom of the spring perch.
  8. Roush2012
    Roush2012 Full Access Member
    107
    88
    Aug 3, 2018
    When I did mine we had to air hammer the living $h!t out of them to get them to move. It took forever to get them to move
  9. MN DOOM
    MN DOOM Member
    19
    Apr 26, 2018
    Minnesota
    not sure if you figured out already or got this resolved. But i recently went through the same problem on a used set of rebuilt shocks i bought off here and my local shop wasn't comfortable possibly fudging up the set screw (understandably) As I wanted to move them up from stock to mid perch. I had just bought some parts from a shop that rebuilds raptor/fox shocks and decided to call and ask what they thought. ended up shipping out to them. They placed the shock in their 20 ton press with seized set screw still in place and moved up to middle perch. worked for me.....
    BenBB likes this.
Share This Page
