GEN 1 Transmission leak?
Discussion in 'Ford Raptor Problems and Questions Forum' started by RDFTS, May 10, 2016.
  1. RDFTS
    RDFTS aka Rick Supporting Member
    12,951
    9,292
    Nov 10, 2013
    Southwest Missouri
    Thoughts?
    [​IMG]
  2. 2014RubyRed
    2014RubyRed FRF Addict
    52
    8,871
    6,925
    Jan 11, 2015
    Galesburg, IL
    Same leak on mine after Snoball. Ford had to remove the transmission and change an internal seal. Ended up rolling the seal when they reinstalled it and removed it again to fix it right. Down about 4 - 5 days total. Pressure tested the torque convertor and ruled that out while they were in there. I think it ended up being a pump seal or something like that.
    It was covered under the warranty though......
  3. RDFTS
    12,951
    9,292
    Nov 10, 2013
    Southwest Missouri
    Well shit, this is going to mess up my paid possibility of making it to TRR next week!
  4. 2014RubyRed
    52
    8,871
    6,925
    Jan 11, 2015
    Galesburg, IL
    It's really a two day job, especially if they have the seal kit and take their time during reassembly. You got time.....
  5. RDFTS
    12,951
    9,292
    Nov 10, 2013
    Southwest Missouri
    Appointment at the dealership tomorrow morning. Rear differential is leaking again for the 3rd time too.
    [​IMG]
  6. Ingot SVT
    Ingot SVT Full Access Member
    144
    107
    Jan 5, 2014
    Issaquah, Wa
    First post^^^^ rear main seal leaking...oil looks too dark to be trans fluid
  7. Trick.Raptor
    Trick.Raptor The Cracker Raptor Supporting Member
    3,928
    7,559
    Nov 7, 2014
    Santa Maria, CA
    I had the exact same "leakage" last October after ROC Fest. I noticed oil splatter on my toybox hitch after towing it over the Sierra pass and saw just one small drop where you have your leak.
    I cleaned it up and nothing until after the Silver State Run and even then it was just moist with a slight drop ready to fall but I did another rinse and it's been slightly moist if that ever since.
  8. Vash
    Vash Full Access Member
    881
    288
    Mar 13, 2011
    OK, USA
    Could be rear main seal. Otherwise, if you've got an oil catch can, the fluid could also be coming from a lose hose near the intake. This could allow oil/condensation to drip down the back of the engine under throttle. Check to insure the disconnects on the hoses are connected completely.
  9. RDFTS
    12,951
    9,292
    Nov 10, 2013
    Southwest Missouri
    Dealership put dye in the motor and drove it for 30 miles and could not locate the leak. They cleaned it up and gave it back to me and said to bring it back in a week so they can see if it leaks again.
    Starting to think when I got stuck in sand, I was in 4HI and even with the pedal almost to the floor, none of the tires would spin and the torque converter perhaps got hot and puked? Was able to crawl out in 4LO without issues.
    [​IMG]
  10. phydough
    phydough FRF Addict
    1,073
    637
    Aug 4, 2010
    My transmission is leaking at the opposite end. Can't tell if it is the pan or rear extension housing yet.
    Does anyone else's cardboard and tinfoil heat shield above the transmission now rest on the transmission instead of being attached to the floor?
Share This Page
