Tire Size??
Roscoe
Hi,
Quick question, which I am sure has been asked several times before. My stock BFG's are about worn out and a buddy just gave me new 35x12.5 R17 Mud terrains. Will they fit with the standard rim size and stock suspension?
Thanks!
Venerous
California
Hi,
Thanks!
From everything I've heard/read so far - 2019 and 2020 you should be fine no rub & no trim or level req. 2018 and below: some slight rub at full lock, eliminated with level like RPG or Eibach springs. (assuming a 14mm tread depth like the KO2 AT) Hope this helps. Stay safe!
R
Roscoe
Thanks for the info! I have a 2017 so even if they rub a little probably still worth running them for a while.
Venerous
California
No problem. They are free (you said your buddy's giving them to you, right?) so, I'd say go for it.
R
Roscoe
Yes, he just purchased a modified Wrangler and these tires came on it. They don’t have white letters so he wants to replace them. I supported his decision which is why I ended up with 4 new MTs. Some guys, more money than sense for sure but he wants a specific look so I get it.
R
Roscoe
Thanks for all the info! Sounds like were mounting some 35's!! Thankfully gas is about to free!
93,171
56,440
jumpcutter
