Strange fluid after few jumps
hosseface
Work
Looks to me just like you have a loose/bad/leaking oil filter.
Go buy a Motorcraft FL820 oil filter at any parts store, a couple quarts of 5w20 oil & a can of brake cleaner.
Replace the oil filter, make sure the old one wasn't double gasketed, top off the oil, start the engine, shut it off, check the oil again, spray if off with brake cleaner and be done with it.
10 minute job max.
Avoid the dealership run around at all costs.
D
Deleted member 12951
Guest
Is this the dealer where you bought it? For a new truck to be leaking they should get you in right away, I would be taking to a manager, general manager preferred.
dark1024
dark1024
Cupertino, CA
I know, I called the dealership where I got it and spend over 40 minutes on hold just to tell me that they can't receive it :/ until mid next month.
dark1024
dark1024
Cupertino, CA
10 minute job max.
I would love to avoid the dealer and the days without my truck, but I'm ashamed to confess that I'm a noob, my skills with motors and that type of stuff is not something I have previous experience, I work in the software industry so all this is new for me :(
aka grumpy car stereo guy
actually its tiffany ford in hollister. i have had bad experiences at the other local dealers but tiffany ford has been good to me. they are also mod friendly.
Vash
OK, USA
I work in IT for a Fortune 6 company and I've done plenty of oil changes and replaced the fluid in my front and rear differentials. Being a "software guy" is no excuse! :p Do yourself a favor and order a service manual online. If you can read, then you can pretty easily do most of what the dealer does and likely better because you won't be in a hurry. Replacing a filter is not big deal at all. Now, a leaky drainplug would be a bit more of a challenge if it was anything other than just being loose.
It'll be a major benefit for the longevity of your truck if you can do your own maintanence. At minimum you'd at least be able to tell if they did crappy work and immediately call them out on it. Service isn't what it used to be.
dark1024
dark1024
Cupertino, CA
thanks for your advice, you are 100% right, that's no excuse!
