Spec-D LED tails installed, love them!
Baddoug
Louisiana
I hope I don't sound like an idiot. but what does "Hyper flash" mean? I have upgraded the lights on almost every ride I have ever owned and never heard this term. I'm planning to change my 2014 Raptor taillights to Recon LEDs and I do not want any problems with them seeing that they cost over 300 bucks. So please any insight in the matter will be appreciated.
DynoDynge
Zavalla, TX
I don't know if I like he hanging tension on the wire pigtails... I may have to figure out some better options than double sided tape... Anyone has ideas please chime in!
Wipe the area you are going to attach to with alcohol & attach with the 3m tape. Same stuff used to attach emblems to the side of vehicles. Mine have never given me any issues.
Red
Panhandle of Texas
Hyper flash is where the light flashes twice as fast as normal.
mudblood
Atlanta
Listen that 3m tape will hold up if you clean the area well first. Or you can go with industrial strength velcro at your local Lowes or Home Depot.
FvilleRaptor
Pungo, VA
So I finally received the other 2 resistors and got the lights installed. They look great. HOWEVER, I know have a major problem. The taillights are not working. The brake lights works when I apply the brakes, however, at night when letting off the brakes the lights go completely out. They were working fine for a couple days and then they just quit tonight. The turn signals work fine. The other wired thing is that the 2 side LED running lights below the tails are out also. The 3 LED running lights on the third brake light work. Could this be a fuse? Any help would be great. I can't drive the truck at night now until I get this figured out. Thanks in advance for any input!
oxfordraptor
Did you check the wiring again? I've had no problems so far.
