Some advice needed
Netix
Banned
Ontario, Canada
Hi im ordering tires and wheels for my raptor. I will have the perch set on middle once i get it. Im looking at some :
Nitto trail grapplers
and fuel off road hostage or octane. I really like the deep dish.
Id like them to stick out from the car abit as well!
I have no idea how to pick sizes and ect. Im looking at either 18" or 20" with 35 grapplers would that work?
Could someone suggest sizes of rims and tires for me please?
Thanks you!
BIRDMAN
Birdministrator
Boston
18" or 20" rims will work and 35" tires will work. stick around + 0mm to +18mm offset with 9" wide wheels if you want them to stick out. negative offset sticks out too much in my opinion.
6.2
Banned
Canada
Personally I'd recommend a 18" wheel. Especially if you plan on using it off road.
-Sent from my iPhone
Netix
Netix
Banned
Ontario, Canada
guys im retarded i don't know what all this means. 18 would be better off road while 20 looks quite mint on the car.
i dont understand the numbers for these items.
So if i choose a 20x12 rim.
Which of these tires to get fitted to the rim?
LT295/55R20 E123/120Q 205-750 19.4 32.91 12.52 8.5-(9.5)-10.0 3415@80
LT295/60R20 E126Q 205-910 19.4 34.45 12.13 8.0-(8.5)-10.0 3750@80
LT295/65R20 E129/126Q 205-790 19.4 35.47 12.13 8.0-(8.5)-10.0 4080@80
LT305/55R20 E121/118Q 205-760 19.4 33.39 12.60 8.5-(9.5)-11.0 3195@65
35x12.50R20LT E121Q 205-720 21.0 35.04 13.39 8.5-(10.0)-11.0 3195@65
37x12.50R20LT E126Q 205-800 21.0 36.77 12.99 8.5-(10.0)-11.0 3750@65
and if a 18x9 rim which tire?
LT275/70R18 E125/122Q 205-870 19.1 33.62 11.10 7.0-(8.0)-8.5 3640@80
LT285/65R18 E125/122Q 205-740 18.9 32.83 11.93 8.0-(8.5)-10.0 3640@80
LT295/70R18 E129/126Q 205-780 19.4 34.57 11.73 7.5-(8.5)-10.0 4080@80
35x12.50R18LT E123Q 205-700 21.0 35.04 13.39 8.5-(10.0)-11.0 3415@65
sorry guys im a noob. and also what is the lug pattern on the raptor?
whtrapta
Ostrich Wrangler
Bolivar/Springfield, MO
The ones that are 35". The first section is the second to bottom tire. The lower section is the last tire. The only numbers that really matter is the first bunch. 35(diameter)x12.50(width)R(radial)20LT(rim size)
Netix
Netix
Banned
Ontario, Canada
thanks so much for clearing that up man!!! cheers!
---------- Post added at 01:27 AM ---------- Previous post was at 01:21 AM ----------
SO to get this right.
This size Toyo open country MT 35x12.50R20 121Q 10/E BW will fit a 20x12 rim no problem?
The rim website has this pdf http://mhtwheels.com/pdf/specs/D508-D509 Octane1.pdf and if you look to the last page where its 20x12 theres a bunch of numbers again do I need to worry about that??
Nick@Apollo-Optics
Houston, TX
None of those tires are wide enough to accommodate at 12" wide wheel. Technically they will fit, but they will be out of spec/safety and not be proportional.
I know you really want wide wheels, but they will stick way too far out. I think your best set up would be a 20x9 with a +1 or maybe with a -12 offset but I still think those would stick out too far.
As for tires, a 35x12.50x20 would work great.
Hocker52
League City, TX
I have 20"x8.5" American racing 893 rims with Nitto Dune Grapplers. They do rub some when having to turn sharply in reverse. The Nittos are 13.11" wide where as the factory ones are 12.5".
jdowens1
Ford Senior Master Technician
Montana
I recieved a early christmas present from the wife and kid they are fuel hostage wheels. Since it was suprise she let phone rep choose the size. They are 17x9 with 4.5inch backspace and +18 offset. When turning they do rub and they are only half inch wider then factory. Since they have only been on two days I havent looked at rubbing yet. They do rub on back of fender but don't hit bumper in front.
