Raptor power upgrade on Motor Trend tv Two Guys garage
Dustan
Boulder Colorado
Found it. Does anyone have this package? This is the first I’ve heard of changing fuel pump and injectors. I wish they got a little more into dealing with the fuel system
Lion74
South Florida
I saw this episode. It looks like the Livernois E85 conversion kit. The new fuel pumps and injectors are for delivering more E85 fuel to make that hp. Mpg’s are horrible with E85 because you need so much of it. The trade off is it’s cheap.
Dr Racecraft
I’ma need about 3.50
Michigan
[mention]wgr73 [/mention] will help you with E85 conversion, he’s done a bunch of work tuning for this
That’s goosetune for those wondering
Xtinct
Nebraska
2017-2020 FORD F-150/RAPTOR T650 FLEX FUEL UPGRADE PACKAGE
https://www.livernoismotorsports.com/product/LPP0118525
I thought that the weak point was in the turbo charger needing to push out more air. The consensus seems to be 1st a tune and better IC. 2nd a bigger turbos even before intake, exhaust or turbo adapters.
If this is true how does pumping more gas into the system help if air flow is the constraint? I could see needing more fuel for E85 but they are claiming 130 HP gains on 93 octane.
xrocket21
Maine
timing. e85 is super high octane so you can run higher boost AND get a little spicy with the timing.
Dustan
Boulder Colorado
It’s cool they talked about the raptor but the show is just a big advertisement. They even pushed some snake oil additive.
White fog
Louisiana
I ordered the high pressure fuel pump and E-85 tune from MPT a while back. Nice performance gain over my old 93 PRX tune. Currently fine tuning my water **** injection along with it. My only feat is that the ONE gas station that sells E-85 will stop selling it!
Badgertits
Ma
why not just run pure ****?
