FRFNewsletter
Well-Known Member
- Joined
- May 4, 2021
- Posts
- 230
- Reaction score
- 0
Click here to view on the web
Highlighted posts
August 21, 2021 * 26 posts * 1,132 views
Erjdrvr said: Hey folks, after the news that the KC F150 plant was shutting down due to new chip shortages, it come as no surprise that Est. Delivery Dates are getting pushed! Four of the trucks ... Read more >>
August 21, 2021 * 11 posts * 315 views
Brownie said: A Supertruck deserves a super license plate. Share your cool personalized plates or ideas here. Read more >>
August 21, 2021 * 9 posts * 194 views
1BAD454SSv2 said: 2019 supercab . So far 180 thermostat. Cobb drop in filter . AFE larger airbox scoop. BBK TB . COBB stage 1 93 octane with Tcm. Fuel 95 octane. Got these runs this morning cooler ... Read more >>
August 22, 2021 * 9 posts * 177 views
lsher101 said: What do you think about this? Will it be on schedule? Read more >>
August 21, 2021 * 7 posts * 100 views
MTF said: Ok, which belt broke??? DID YOU BREAK BOTH??? Because there are two separate belts!!! Because it sure sounds like it. Since you're looking to warp around all the pulleys. One is ... Read more >>
August 21, 2021 * 4 posts * 111 views
CoronaRaptor said: I'd like to know what the factory jack is for? It's just as useless. Read more >>
August 21, 2021 * 3 posts * 79 views
Michael Edwards said: TwizzleStix thanks for your thoughts. First as stated I'm no mechanic, but yes I checked the oil levels without the trailer and level. It was right at the full line. As for the ... Read more >>
August 21, 2021 * 1 post * 40 views
Andres Aguilar said: hello, should i use the oem ball joint for my LCA or just use moog? Is there any performance difference between them? Read more >>
August 22, 2021 * 1 post * 37 views
FRFNewsletter said: Click here to view on the web Highlighted posts Here they come!! August 20, 2021 * 11 posts * 459 views Ford F-150 Raptor General Discussions [GEN 3] My B&0 sub/amp upgrade (2019 ... Read more >>
August 21, 2021 * 1 post * 39 views
James O said: I just traded my Z06 for a Raptor and will be adding a winch. Can I use a regular winch with manual clutch release? Just trying to figure out the main advantages and disadvantages. ... Read more >>
Continue reading...
