Purple cranium rock guards
Blind1
Central Alabama
I wonder if you can get these to fit over an aftermarket/high capacity cover.
I believe Wiz has done that. It's has been a while since I read his build, but I do remember him installing a big aftermarket axle cover and installing a *** on it as well. (or maybe my memory is seeing things)
FvilleRaptor
Pungo, VA
So can a full spider be installed over the stock 2013 cover without removing the cover. I don't want my diff to open up if I install this.
J DAMAGE
NJ
How are these installed without removing the differential cover like it's advertised?
Sent from my SAMSUNG-SGH-I337 using Tapatalk
The factory cover is siliconed on real good, you remove the bolts its not going anywear, just changed my cover and it was a bitch getting the factory cover off.
Thats what the spider is for, placement over your cover for added protection.
mudblood
Atlanta
Any torque requirements for the diff bolts? This is a very inexpensive modification I am darn interested in.
Vash
OK, USA
I think the torque on both front and rear diff bolts isn't much. Like 16 or 17ft-lbs.
