GEN 2 Is anyone running Alcon brake kit with method wheels 0 offset? (Is 5mm spacer needed?)
Notn41
I have a brand new full Alcon brake kit set. Does anyone have these on their method mr305s 0 offsett? I know they will fit with the 5mm spacer but I’m going to 37s eventually and with that spacer they will rub. Does anyone know if they will work with method wheels without the 5mm spacer in the front? (And please don’t suggest changing wheels)
Thank you in advance
nikhsub1
Los Angeles
They should fit, but it really depends on spoke design. The OEM wheels need the 5mm spacer, but they are what, +36ET? The 0 offset gives you an added 3.6CM more than the stock wheels.
