Intercooler piping blowing off
Donovan
DC
CVF FMIC
This is the second time this piping has blown off, typically happens at WOT 20PSI. Any tricks to resolving this issue? Perhaps a diff clamp? Someone said use hairspray on the metal side when marrying the boots to the pipes. This is happening to the cold side.
DoJo.
DO MORE PUSHUPS!
Hairspray works on motorcycle grips, not sure if it’s going to provide any tangible benefit under this kind of load though.
Booth9999
Idyllwild
Maybe your clamps failed? That’s odd I would think you need to tighten them more or replace them. 20PSI isn’t that much pressure.
Donovan
DC
Cheers for that. Is this what you used for your aftermarket FMIC?
ok, so you still need more push ups, but for this particular activity I’m thinking some more curls and reverse wrist curls are more in line with what you need to focus on. you don’t want us labeling you an honorary prius driver. :eek::p
