GEN 1 Ignition switched fuse/relay for Hood LED Lights as DRL’s?
jgwoody
So I just bought the iJDMToy adapter harness for my 2013 Screw that converts your hood mounted LED lights to DRLs. It requires tapping into an accessory / ignition source in the engine bay fuse box to turn on lights. Does anyone know which relay/fuse can be used? I’ve searched everywhere online, here and elsewhere, and can’t find any definitive info. Thanks for any help!
J
jgwoody
Yeah I considered it, but for that route I might as well just use the headlight switch to turn them on/off lol. I want something automatic that makes them come on during everyday driving with the headlight switch still in auto.
Dane
Littleton, CO
And that's what the Aux switch would do... Just leave it turned on. It's accessory only, it'll turn on/off with the truck.
J
jgwoody
No installation instructions. Had a link to generic video, which basically said the same thing you just said... use voltimiter to find a ignition switched fuse under the hood. Will go buy that tool later, was just hoping someone with a 2013 already knew off the top of their head.
Gary E
Medford, Oregon
Is the harness wires long enough to get routed all the way down the hood, then forward to the fuse box?
J
jgwoody
Actually no, it’s about a 8–10 inches too short. I was going to splice in/ solder some extra wire to make it longer. Either that, or tap it into an ignition switched wire near the driver side firewall.
