Gear oil help please!
POORMPG79
Longview Tx
Wanting to change the front and rear differential gear oil in my 2010 Raptor can anyone tell me what weight oil goes in each as well as quantities and if I also need a friction additive or not as well thank you in advance.
Ricoman
WASHINGTON STATE
Changed REAR in my 2014 last year....used AMSOIL SEVERE GEAR® 75W-90 ... its expensive...but so is a Raptor... think it was around $12 per qt. at time...No need for Additive it has it already.....
Hard to say which "Brand" is best,or working best...and you will go crazy reading all the reviews.... so all I can say is I have not blown the rear up yet..so must be working....:33:
I believe you need 5 qts .... should say so in manual.
Edit after reading a few other replies.......my mistake...that was 5 pints....not qts... Also....as I understand the 75W/140W is for extreme condition and if your towing ..... in my case,its just normal highway driving and was told 75W-90 is the way to go,front and back.
Ruger
Northern Nevada
The factory owner's manual for my 2011 says:
- Front differential: 80W-90, 3.5 pints
- Rear differential: 75W-140, 5.5 pints
- Transfer case: 1.6 quarts of Ford Transfer Case Fluid, but Ford has abandoned its proprietary fluid and the spec is now for Mercon LV.
julien194b
Europe FR.
if you take the good oil you need, why do you want add something else, absolutly not necessary, may be worse...
